Tire Data Calculator
Hello All,
I've just finished the updates to the Tire Data Calculator. http://bndtechsource.ucoz.com/index/...alculator/0-20 Now not only can you can input tire & rim sizes, you can input air pressure, vehicle speed and corner loads. The outputs are as follows: Output Spec. Data Result Tire 1 Result Tire 2 Spec. Design Rim Width (manufacturer’s measuring rim) Spec. Tire Outer Diameter (at spec. air pressure and no load) Spec. Tire Section Width (at spec. air pressure and no load) Spec. Tire Section Height (at spec. air pressure and no load) Spec. Static Load Radius (@ spec. maximum load and spec. air pressure) Spec. Tire Rolling Circumference (@ 60 km/h, spec. load and spec. air pressure) Spec. Dynamic Rolling Radius (@ 60 km/h, spec. load and spec. air pressure) Spec. Tire Stiffness Rate (@ spec. load and air pressure) Tire Air Volume (@ spec. load and air pressure) Output Vehicle Data Result Tire 1 Result Tire 2 Vehicle Tire Section Width (@ vehicle load, speed and air pressure) Vehicle Tire Section Height (@ vehicle load, speed and air pressure) Vehicle Tire Deflection (@ vehicle load, speed and air pressure) Vehicle Tire Rolling Circumference (@ vehicle load, speed and air pressure) Vehicle Dynamic Rolling Radius (@ vehicle load, speed and air pressure) Vehicle Tire Stiffness Rate (@ vehicle load, speed and air pressure) Contact Patch Width (@ vehicle load, speed and air pressure) Contact Patch Length (@ vehicle load, speed and air pressure) Contact Patch Area (@ vehicle load, speed and air pressure) Speedometer Reading (Tire 1 is assumed accurate) Tire Suspension Comfort Value Please let me know your feedback. Thanks, bndtechsource |
Sorry. try this link address:
http://bndtechsource.ucoz.com/ Then select the Tire Data Calculator from the page list. |
Pretty cool, thanks! |
Hello All,
BND TechSource has a new and improved website! Please visit us at https://bndtechsource.wixsite.com/home or https://bndtechsource.wixsite.com/ho...ata-calculator for the Tire Data Calculator which now has interactive input for loads and air pressures and outputs for stiffness rates and deflection. Please let me know your feedback. Thanks, bndtechsource |
| All times are GMT +3. The time now is 05:56. |
Powered by vBulletin.
Copyright ©2000 - 2026, Jelsoft Enterprises Ltd.
