#501
Clockwise.
#502
#503
Smile you are on candid camera !
I have been honored with a article in AMCAR Magazine, leading lobbying and American Car owners organization in Scandinavia. Thanks to the many Norwegians who made my visit unforgettable, well somethings I may want to forget....not many...
http://www.amcar.no/ Jack
Join the Corvette Vagabond Community! Like me on Facebook Follow me on Twitter Check out my website |
#504
Trial Fit of Trim
I got home and unwrapped the polished trim. I will do a post on Back Bay Customs, a great mod-hot rod shop, that helped me out with polishing. I wanted to trial fit the trim. The front piece must be placed so that equal distance of ends are under side trim , for trim to fit in corners. I put on the top piece first, followed by the outer side trim only, with only one screw to hold it to birdcage loosely. I put one end of front trim into side piece to get right distance under trim. I clipped down 1/4 of front so I could mark trim and having marked windshield , I had a mid point to always line up front piece for later final fit. I had no trouble with clips catching as I cleaned out the space between rubber and front fiberglass, as stated in earlier post. There still is a slight problem in the corners , as the rubber does seem to bow out a bit, pushing the trim away from the body, the clips catch but there is a gap. I am not going to fix the rubber. no leaks in windshield. I will fill it with a flexible sealer. I hope this helps others in trim work. Total time to put trail fit about 1 hour. Should take about the same for final fit. It helps to have two people , one on each side to slide side pieces into place with front at same time. Or, if you start on one side as I did, get two or three clips to catch, then go middle an lock down center two clips , go back and finish one side and work your way to other side, stop about two clips from end, side in side piece with front, push together and down, screw in side piece , all should be clipped. Again, there must be enough space between rubber and fiberglass to push trim edge in far enough to catch clip. With new clips, get one to catch , look at it , and see how it catches. You must get it in same position alone the front for clips to grab trim. I have original clips , so it was lack of space , that would hinder clipping, not clips. Now I have to take it all off, side pieces first, slide them out from front trim, get first clip to release and off you go. I will post pictures of removal as I have to finish cleaning up excess sealer from the windshield install last year.
#505
Trim and Hood finished
I am continuing with engine bay clean up and maintenance. The hood has been repaired and painted. My heater motor, still works but has a loose bearing, and rattles when turned on. I had thought it was the fan hitting the enclosure, but after taking motor out and bench testing it, the motor itself rattles. I can move the shaft in and out about 1/8" or more.
I have ordered a new motor as I don't believe you can take the motor apart. Only $29 from Zip Products for a new one. I will use the old fan as it is still in good shape. Even though I completed a restoration of the engine bay only 3 years ago, 50,000 miles will produce a little dirt and grime. On the trim, the photos show how I put on the front piece. It is very important to make sure the there is room under the rubber, to slip in trim. Soap and cleaning out all the sealer from windshield install will help. I should have the car back together in a few days. Motor Fan Overflow Trim need to find midpoint Job done Hood
#506
Looking good.
#507
A magical moment !
You walk around grumpy, nothing seems right, people will ask, whats wrong ?
But we know what is wrong, and we have done something to fix it. But you have to wait, just a bit if you use the right vendor. And then it happens..you come down the driveway, afraid to look up....and then you do .... And then the magical moment ! You float out of the car and walk up to the door and there it is.... In my case, Zip Products, new heater motor and other little goodies
#508
Rebuild the Holley 4160 or leave it alone ?
As I prepare the car for a long season of driving both in the US and Europe the engine has been my focus.
The car has 50,0000 miles on engine since rebuild in 2010 New carb Holley 4160 put on in 2010 Correct L-79 66 Roadster All new wires, timing springs, oil, (1,200-1,500 mp Qt.) plugs Car began to get 9-10 mpg in winter after I got it back from Europe (Dec) Was getting 14-15 hi 12 mpg town Put in all new stuff as listed and now car runs great. 5,000 gallons of gas has gone through it. I have worked on the carb before and am familiar with setting floats etc. Should I , do nothing as the car is running fine Should I rebuild carb with all new parts from Holley with successful outcome Should I rebuild carb with horrible results , poor performance and lots of self recriminations Should I send the carb to midyearvett and save a fortune in gas because I will not be driving my car while he has my carb Should I ask Dahogan to ask Frank , because I have not told him about my plan I do need to get Lars paper on modifications to the Holley heat shield that I want to install to prevent accelerator pump boil over. What would you do ? Jack ps does the gasket go directly on intake then insulator, or insulator the gasket - carb
#509
I don't remember a thing
I remember going out to the garage, gas fumes I woke up with gas and oil on my hands. What could have happen in 30 minutes ?
I took the car for a ride and was hungry I got back in my car and drove toward home. I remember posting to Frank.....it gets hazzy ... There was a ride to Portland, I remember saying hello to some friends and then I looked in the garage Frank, I found it , wet and oily , put it in a box , you should get it in a few days
#510
1960 Caddie tail lights ?
