#1311
Toki tää on aina pelkkää matikkaa kattelin just että mun Tamron 70-200mm f/2.8 alkaa jostain 160mm ylöspäin vetään dunkkuun tota 135 ällää doffin suhteen täydellä aukolla kuvattaessa. Eikä mun 85mm f/1.4 pääse edes ihan iholle doffissa täpöllä metrin päästä 135mm 2.0 kanssa. Jos plörtsii halujaa pitää olla niitä miltsei vaan mahdollisimman paljon.
The eyes are useless when the mind is blind... |
#1312
Sit vähän bokehin tuottamisesta asiaa,,,
In terms of image quality this is as good as Canon gets, and really about as good as Mamiya 7 even. First bokeh: bokeh comes from aperture size, not f-stop. The 200/2.8, 135/2, and 85/1.2 all have about a 72mm aperture for the light to go in, which basically determines the size of an out-of-focus highlight behind a given subject at a given distance. In other words, if a highlight circle is half your subject's head size with one of these, it will be with the other two too. (In comparison, 50/1.0 only has 50mm aperture and a blurred highlight only half the blur. Think about that: this is twice as blurry as a 50/1.0.) That said, while the 200mm/2.8 puts a nice blur behind your subject, the 135/2, with same subject at same distance, gives the same blur but over twice the area of scene. This means you can pick out your subject in focus against a HUGE wall of bokeh, which is much more impressive. Another way to think of it is 2x blurrier than 135/2.8, such as the L zoom. (The 85mm/1.2 bokeh turns into football shapes off-center, so while it makes killer images the bokeh's lacks the perfection of the 135/2 or 200/2.8.) Yet another way to describe the bokeh is that people are a bit more used to seeing 200/2.8 because the L zooms do that shot. People are NOT used to seeing perfect bokeh on a shot of twice the area, because only this rarely-used lens can get this shot. As far as image quality: as long as your shutter is high and you're exactly in focus, even at f/2 this is as sharp as lenses get. Even corners are excellent. But its hard not to talk more about bokeh: even when the background is near, it can still be out of focus enough to make your subject really stand out in a 3D look. Its not only beautiful but very very rare as only this lens can do it.
#1313
Tässä omasta pirssistä räppästy kuva viime lauantain mailiajosta Pudasjärven lentokentältä:
Ja originaalikoossa: https://dl.dropboxusercontent.com/u/...IMG_8473_2.jpg
-BMW M3 -11 -MB C180 Kompressor -06 -SeaDoo RXP 215 -05 -Husqvarna R320 -14 |
#1314
Hieno fiilis Sorry, tuunasin pikkasen (makuasioita kaikkityyni)
Opel on PoP Astra WRMBCE Walter Röhrl Midnight Blue Comfort Edition |
#1315
Huomenna aamulla olisi sitten se unelmakeli salaisille unelmille, siis todella paksussa sumussa kuvatuille corveteille, esim. jonkin sillan päällä (Lauttasaaressa... tjsp). Tai että auto näkyy ja taustalla olis sumun piilosta pilkottava graffiti... tai kellastunut puu jne. Tai jossain veden lähellä otettuna... usvasta kurkkaa...
(en tiedä olenko yksin fantasiani kanssa) vai oliko mun pizzajauhoissa jotain epäpuhtauksia, vesikin oli keltaista.
No vette at the moment |
#1316
Meteoriitit oli väärässä taas. Ei mitään sumua näkynyt. Illalla oli loistava alku, mutta aamulla oli liian kirkasta.
#1317
Mulla on sulle todella paksussa sumussa kuvattu patonki! Laitan illemmalla |
#1318
Vaikka ei mitenkään corvetteihin liity, mutta kun tuota sumukuvaa haviteltiin ja sattumalta sellaisen eilen otin niin venytän omia sääntöjäni tällä kertaa
#1319
Hyh, kuka tuollasella ajaa? Siinähän on jotain itikanraatojakin keulassa.
no niinpä! Ja voitko uskoa että kuskilla oli vielä baskerikin pääsä! |
