  #31
Old 28.11.2009, 13:44
sevy.8's Avatar
sevy.8 sevy.8 is offline
sevy.8 on oikealla tiellä
? That you can pop the trunk and also pop the gas cap cover by
pulling on metal lines hidden in the back.
● The little slotted cover on the dash behind the steering wheel is
where the inside air temperature sensor is located.
● All of the option codes are in the glove box.
● Tire inflation recommended pressures are on the driver’s door.
● The thing that looks like a little LED near the DIC buttons is a
light sensor.
● The thing that looks like a little LED near the defroster vent is
a UV sensor for determining A/C usage to compensate for the heating
effect of the sun.
● The build sheet is in the front re-bar.
● If you leave your turn signal on, in about 1 minute it will start
to ding (loud enough to hear over the stereo) to let you know you
have old timers disease.
● You can reset the oil life by pumping the gas pedal 3 times (but
not with the engine running).
● Hold down the reset button while on one of the trip odometers and
it changes that reading to the miles you’ve traveled since last
starting the engine.
● Hold down the Active Handling button for 5 sec. to engage
"Competitive Driving" on cars equipped with active handling (2000
and previous years must be stopped.)
● If you pull the seatbelts all the way out while you’re buckled in,
they ratchet back in to hold you tighter into the seat. (then move
the seat forward to make it extra snug -- Leafty)
● Simply remove fuse #2 under the hood and your DRLs will be out
permanently. Only thing affected is that when you unlock at night
using the key fob your front turn signal lights and back up lights
will not flash. Your front turn signals will operate normally,
however.
● The side-view mirrors can twist both forward and backward,
decreasing the chance of damage if struck.
● There is a release opening with a flap to let air out of the car
when the hatch is closed. It is located just above the driver side
rear compartment behind the carpet and on the side of the car. Not
that it really works well.
● Also you can ground your amp to a screw/bolt that holds the rear
middle compartment to the frame.
● If you have a 6-speed car you can pop the trunk when the car is
running by lifting the e-brake.
● There is a spot on the driver side just out of the middle
compartment under the carpet for the lug nut key. You should have a
compartment on the drivers & passenger’s side (in the trunk) and a
center compartment. On the left (drivers) side of the center
compartment, on the left side where the center cover fits, there is
an ‘indent’ that holds the wheel lock key.
● If you turn on the headlights, then go to parking light position,
the lamps remain up but the headlights are not left on.
● If you have the passive entry feature: If you lock the keys in the
car, wait a few minutes and then shake the car. That will unlock the
car.
● HUD has a shift light for the manuals.
● You can easily shift the M6 trans up or down without the clutch if
you match revs. (Not great for longevity, however.)
● You can eject the cd from the in-dash player without turning on any
power. Don’t even need key in the ignition.
● The cruise will disengage if you purposely make sharp side to side
turns while cruising at say 60-80 mph.
● When the engine is shut off, you can get the odometer reading by
turning on the parking lights.
● You can program setting #3 (both memory buttons at once) in the
seat memory to run the seat back and steering wheel forward for
getting in/out of the car with the engine running.
● If you hate DRLs you can pull the e-brake ONE click and they go off.
Power
First you need to know how your car is doing. A trip to the dyno can
give you quick answers.
Tuning software can diagnose and tune your car. LS1Tech and HPTuners
are two popular tuning packages. At some point in the future, both
packages will be able to do scanning with incorporated wideband
sensor support. At this time, December 2004, only HPTuners can do
both.
Popular upgrades:
Cold air intakes: Vararam, Halltech, Blackwing, zip-tie
Intake manifolds: LS6, LS2, LSX, Wiend, sheetmetal
Cat-back exhausts: B&B, Borla, Z06 Ti, Corsa
Long tube headers: LG, Kooks, TPIS, Stainless Works, Breathless,
Jet-Hot, GHL, QTP
Superchargers: ATI (go to A&A), Vortech, Magnacharger
Turbochargers
Stroke & bore
Head & cam packages: TEA, AFR, TSP, Patriot, Cartek
Tires: Kumho Ecsta MX, Nitto Extreme RII
The convertible and coupe (it's really a targa) come with run-flat
tires, with 17" wheels in the front, and 18" in the rear, with tire
pressure sensors. The Z06 comes with non run-flat tire, but has a
tire repair kit. Switching from run-flat tires to regular tires
typically allows the C5 to ride softer, accelerate faster, and corner
harder, but if you use the tire repair kit (goo) on wheels with the
unobtainium tire pressure sensors, you'll destroy the sensors. No C5
has a spare tire. The best way to improve the handling of any car is
usually thru the tires.
Aerodynamics, gearing and top speed
The hardtops and Z06 have shorter rear windows, are less aerodynamic,
noisier, and weigh less than the standard C5 couple like mine. Even
though the Z06 has more hp than standard C5’s, they have a lower top
speed than manual Z51 C5 coupes. This is due to both aerodynamics
and gearing. All C5’s top out at redline in 5th gear, so a taller
5th gear, or much shorter 6th gear, or taller redline is required to
go faster. All else being equal, a Z51 coupe will still go faster
than a Z06. Above 190 mph, air builds up under the front of the car.
This can be solved with a vented hood like the ACP C5-R or MCM hoods.
Weight reduction
You can achieve substantial weight reduction with the following
modifications, while still having a car that's very comfortable to
drive. Most of these modifications will directly increase (and
decrease in a few cases) the safety of the car, while safety is
indirectly improved due to the better handling and limits of a
lighter car. Fighter pilots say "speed is life". Acceleration,
deceleration, and lateral acceleration are all forms of acceleration,
and lighter cars accelerate better in each of these ways because the
tires have less mass to control....thus a lighter car is a safer car.
Lighter cars have better moments of inertia which allows them to
turn in more easily and roll less. Lighter cars are also easier on
the tires and gas.
Old 29.03.2010, 12:35
sevy.8's Avatar
The 1998 Chevrolet Corvette Intelligent Owner’s Manual
http://www.safepic.com/corvette/
Old 30.05.2011, 09:42
sevy.8's Avatar
Eri osien kiristysmomentit ja C5 mallien eroavaisuudet
http://www.eliteengineeringusa.com/usefulinfo.html
EDIT. Aika mielenkiitoinen C6-C5 korimuotoilu vertailu
Old 06.06.2011, 14:37
sevy.8's Avatar
C5 korjausohjeita ja "pikku vinkkejä".
Sisältää myös videoita:
http://www.corvette-web-central.com/C5repair.html
kaikenkaikkiaan hyvän oloinen tietolähde:
Old 20.09.2011, 14:51
Maamoottori's Avatar
Paljonko -02 vuomallin Zetan vääntö NM:ssä?
Old 21.09.2011, 12:59
sevy.8's Avatar
http://www.z06zone.com/c5z06-techspecs.php
Olisko noin 540 jos moottorin väännöistä oli kyse
Old 27.01.2012, 21:23
VetteMan's Avatar
VetteMan VetteMan is offline
President
C5 HUD asennus
Lisään tähänkin ketjuun tietoa HUD asennuksesta C5seen, jossa ei HUDia alkujaan ole.
Kojelauta pitää irroittaa asennusta varten, siihen hyvät ohjeet tästä linkistä.
97, 98 ja osassa 99 mallien mittaristoissa ei ole HUD projektorin liitintä, joten autoon pitää vaihtaa myös mittaristo sellaiseen jossa liitin löytyy.
Liitin projektorille on mittariston päällä olevassa kolossa.
Lisäksi tarvitaan itse projektori, asennuskehys kojelautaan, sekä HUDin kytkimet mittariston vasempaan reunaan ja johtosarja kytkimiltä mittaristoon.
Huomioitavaa ainakin 97 ja 98 mallien kanssa on se että airbag valon polttimo pitää siirtää mittariston sisällä eri paikkaan.
Uudemmissa malleissa se on oikeassa alanurkassa ja 97-98 malleissa se on kierroslukumittarissa turvavyön merkkivalon vieressä.
Tarkista airbag valon paikka vanhasta mittaristosta ennen purkua!
Jos polttimo pitää siirtää, niin sille on paikka uudemmassa mittaristossa.
Polttimon paikan vaihto vaatii mittariston purkamisen.
Mittaristo purkuu takapuolelta ruuvit avaamalla ja purkamalla UV valojen ohjauksen edestä pois.
Polttimo vaan siirretään oikeasta alanurkasta kierroslukumittarissa olevaan airbag valon paikkaan.
Kun tarkistat vikakoodeja uudemman mallin mittariston kautta, niin huomaat että siellä on uutena kohtana SDM modulin diagnostiikka.
Mittaristo ei saa siihen yhteyttä ja ilmoittaa NO COMM. se on täysin normaalia!
Koska airbag järjestelmä on erilainen 97 ja 98 malleissa, eikä kommunikoi mittariston diagnostiikan kanssa.
Old 15.04.2012, 11:05
hanhi27
This message has been deleted by hanhi27.
  #39
Old 03.01.2013, 22:47
sevy.8's Avatar
Löytyi asiallinen sivusto missä DIY ohjeita:
http://www.smokinvette.com/corvettef...=61&order=desc
Tämä kirjanen saattaisi olla myös aika hyvä. Huom! Kaikki sivut ei näy esikatselussa:
http://books.google.fi/books?id=1TPC...page&q&f=false
Old 02.07.2013, 21:22
sevy.8's Avatar
Päivitetty DIY, aika hyvä:
http://forums.corvetteforum.com/c5-t...l-in-here.html
Täältä löytyy mm:
Post #2 C5 Headlight gear replacement ****also see post #22 for other version**
Post #3 Installing Clear Corner Lights
Post #4 Connecting wideband via EGR or A/C Pressure in HP Tuners
Post #5 Reuse original shift boot with C6Z06 shifter/****
Post #6 HOW TO PUT 99-02 PCM into 97-98 Corvette WITH PICS!
Post #7 & 48 How to replace TPM sensor batteries
Post # 8 Narrow band oxygen sensor emulation with a LM-1 wide band
Post # 9 AC Refrigerant charge level
Post #10 Intake manifold Removal
Post #11 How To Fit C6 Fender Guards on a C5
Post #12 DIY Trunk Lid Liner
Post #13 Sun Visor Fix
Post #14 Heated Seats Installation
Post #15 Retractable Antenna Fix
Post #16 How to fit a Pioneer AVIC N1
Post #17 Simplified differential output shaft removal
Post #18 Outside mirror repair
Post #19 Installing interior electrochromic mirror
Post #20 Repair Dim HVAC controller
Post #21 How to fix leaking turn signal housings
Post #22 Headlight gear replacement (version #2)
Post #23 Rocking Seat Fix
Post #24 How to install a FAST 90/90
Post #25 How to install Auot Dimming mirror in car that didn't have one
Post # 28 DIY Rear Hatch Mechanism fix.
Post # 30 How To Refurbish a C5 Hoodliner
Post #31 Z06 screened Front License Plate Mod
Post #32 Popping rear axle fix
Post #33-35 Corbeau A4 Seat and Rail Installation
Post #36 DIY Exhaust Hanger repair - without ordering the hanger.
Post #37 Front License Plate Fresh Air Screen Mod
Post #38 How to refinish your C5 clear Targa Top.....
Post #39 Headlight switch failed. Decided to repair instead of replace…
Post #40 dash removal and HUD install
Post #41 Vette Essential's Full Custom Seat Cover Replacement
Post #42 TheRadioFlyer's LED "halo" tail light mod
Post #43 Vette Essentials: Replace any interior piece: shift boot A4 and MN6, counsol lid, ect
Post #44 bunch of misc links, threads, and DIY's ..if you can't find it elsewhere
Post #45 Leaky rear fix...with pics
Post #46 Replacing TPM batteries
Post #47 Multi-Function Switch / Headlight Switch / Blinker Arm Removal
Post #48 - DIY Flasher Bypass.
Post #50 How to lower your C5 (3 different threads)
Post #51 DIY Repair a curbed polished rim
Post #53-56 Fix airbag light that stays on
Post #58 Power Seat Issues (formerly a sticky thread)
Post #59 Oil Pressure Sender Relocation How To (former sticky)
Post #60 How to fix exterior mirrors with broken swivels (former sticky)
Post #61 C5 Differential Rebuild
Post #62 How To Properly Jack Your C5
Post #63 How to replace your AC compressor
Post #64 Door handle LED install
Post #65 Service ABS, Service Traction Control, Service Active Handling and EBCM Tutorials
Post #66 Evil-Twin's Rotor Cleaning Technique
Post #68 How to Replace Halo Weatherstripping on a C5 Coupe
Post #69 Clutch Install guide from forum member Dope
Post #72 Upgrade TPMS
Post # 73 Oil pressure sensor replacement without cutting or intake removal
Post # 80 The $40 fix for broken side bolsters [pics]
Post #81 Tips on shocks, sways and lowering
Post #82 Clear Corner lights Version #2
Post #83 AntiVenom Mod
Post #84 Flasher Switch
Post #85 Another DIY Jacking Puck thread
Post #86 DIY AR Header Install on my 1997 C5 6 speed car (by bucketlist1957)
Post #87 Z06 rear Brake Duct Template * FREE *
Post #90 Link to C5 DIC Codes
Post #91 Torque Converter Install
Post #92 Lowering C5 the right way
Post # 94 When air comes out of all AC vents: How to Fix w/Pics
Post #95 How-to-repair-EBCM-avoiding-costly-repairs-through-ABSfixer-or-Fleabay
Post #98 Window Motor Rebuild
Post #100 Links to Steering Position Sensor
Post # 101 DIY for adding AUX Input using GM10-AUX do not need COR HAR Harness
Post #102 Headlights stuck in bright / dim Fix
Post # 103 DIY GM #12102635 for TPMS upgrade
Post #104 Sideskirt DIY...make your own...10-13-2011
Post #106 How to remove stock control arm bushings with only a vise and free Autozone Loaner Tools.
Post #107 Lazymans Rocking Seat Fix
Post # 108 Weights, measurements, strengths etc.
Post #109 Fuel Regular, Premium, Real Gas
Post #110 Planning on Wheels and Tires? Not sure which tires to go with? AH/TC issues?
Post #111 Making the C5 go the distance!
Post #112 The Anatomy of a Hydraulic Lifter
Post #113 Multifinction Turn Signal Lever
Post #114 Engine Grounds
Post #115 1997-2004 PCM Pinout
Post #116 C5 Ignition Switch Repair
Post #117 C5 T56 Rebuild 5th-6th Extension Shaft Details
Post #118 Leak Checks
Post #119 Opinions on Propshaft Rubber Couplings
Post #120 ACA HID install prep - bulb jiggle "fix"
Post #122 Sound Deadening and Stereo Install (step by step)
Post # 123 Fast 92 intake with LS2 Throttle Body install
Post # 124 An Alternative Fix For The P1416 Code
Post # 125 C5 steering wheel with a regular steering wheel puller
Post # 127 How to get your seat out when there is no power or broke
Post # 128 Mesh Side Cove DIY
Post #129 Dipstick Mod
Post #132 How to check fluid level in A4 Transmission
Post #135 18 minute hazard switch replacement
Post #136 DRM transmission cooler install process pictures and helpful hints
Post #142 Adding AUX/iPod jack into the stock C5 Headunit
