Old 11.03.2009, 14:11
tumir's Avatar
tumir tumir is offline
tumir on oikealla tiellä
Shift Improver Kit
Morjens!
Sain tällaisen kitin kaverilta:
Shift Improver Kit
Two kits in one
Stage 1: RV/Heavy Duty
Stage 2: Street/Strip
Eli onko kokemusta tai voisiko joku kertoa moisen kitin hyötyä jos sen corvetteeni asennutan.
Terveisin,
Tumi
Old 16.03.2009, 20:14
BoB's Avatar
BoB BoB is offline
BoB on oikealla tiellä
kit
Nooh joko sait asentajan kiinni? eli joko on palikat laatikossa?
Old 16.03.2009, 20:24
BoB's Avatar
BoB BoB is offline
joku viisas aiheesta sanoi näin ( tällä foorumilla ) "ei muuta kaaviota tai toimintaa mitenkään mut terävöittää vaihtoja reippaammalla kaasulla"...
eli jos tuo auttaa edes jotenkin
Old 16.03.2009, 21:17
Toxic Flame's Avatar
Oppositional defiant DO
Niin ja tuhoaa laatikon samalla...
Old 17.03.2009, 17:01
BoB's Avatar
BoB BoB is offline
Älä hemmetti onko näin? kerrotko hivenen lisää? kiinnostanee varmaan tumiriakin jolle se on nyt asennettu kait?
Old 17.03.2009, 21:25
Jos shift kitistä on kysymys niin sehän vaan terävöittää pikkasen vaihtoja. Mut jos laatikolla on ikää niin voi tehdä jäynääkin.
An automatic transmission's main focus is smooth shifting between gears. To accomplish this it often goes into two gears at once while shifting up, which is known as a shift overlap. In these cars, it is a kit that can reduce or eliminate the shift overlap. It will also reduce wear because the transmission won't be trying to drive in two gears at once.
Typically, adjusting the shift 'pattern' in an automatic gearbox involves interrupting the signal from the ECU to the transmission (usually with a switch, though the adjustment can be made permanent). The resultant shift pattern is usually very aggressive (it will 'bang in' to gear) thus making a car a handful in the wet as well as opening the possibility of damage to already weakened transmission internals. It is advised that you service your transmission more thoroughly than usual if you undertake this adjustment.
Old 17.03.2009, 23:04
Terävöittää vaihtoja myös pienemmällä kaasulla niin että huomaa. Mutta äkkiä tottuu...
Old 17.03.2009, 23:25
Kyllä ainakin tuttu laatikonkorjaaja suositteli että shift kittiä laitettaessa tulis huolehtia että laatikko on muutenkin kunnossa(kuullostaa kyllä hyvin järkevältä).
Old 18.03.2009, 03:09
Automaattilaatikoita saa kuulemma nykyisin terävöiteltyä ihan kapulallakin mut ei oo kyllä mitään tietoa eikä kokemusta kuinka paljon tuollainen softallinen viritys eroaa mekaanisesta.
Old 26.03.2009, 16:44
99C5's Avatar
99C5 99C5 is offline
99C5 on oikealla tiellä
Juu itse olen tehnyt vaihteisto softamuutoksen superchips Cortex kapulalla ja eron huomaa! Itse olen ollut vallan tyytyväinen. Pakkojen paineille ja vaihtokohdille on muutamia eri tasoisia asetuksia.
(Niin ja sen verran vielä että eilen Vetestä vuoden ensi savut, eiköhän tuo jo 1.4. lähde vakuutuksiin)
