Old 17.06.2009, 22:46
myky's Avatar
myky myky is offline
myky on oikealla tiellä
Ikkunoiden "lonksuminen"?!
Löytyneekö oviverhoilun alta ikkunaan kiristysmahdollisuus, kun ikkunat lonksuu toista senttiä kun heiluttelee sitä käpälällä. Välillä kuskin ikkuna osuu "ohjaritappikynnyshommaan" ja ikkunaan jää siten monta milliä rakoa! Saako siis säädetyksi kireeksi?
Old 17.06.2009, 23:15
Jos lontoo taipuu niin tässä ois ohjeet
Window Adjustment 101
Door Window Height Adjustment (Major)
Door Window Height Adjustment (Minor)
Door Window Tip-In Adjustment
Baseline Setting
Remove door panel & water deflector.
Remove door speaker assembly.
Remove window door clamp sight access plugs.
Position window to access clamp nuts.
Disconnect window switch.
Loosen window clamp nuts through door top opening.
Regulator in full UP position.
Loosely tighten rear window clamp nut.
With helper, position window to door opening.
Tighten window clamps to 89 lb/in.
Open door and install window clamp access plugs.
Install speaker, water deflector, door panel.
Perform minor height and tip-in adjustments as necessary:
Window fully UP.
Remove large access plug (under front of door).
Loosen window regulator front channel mounting nut.
Remove reflector from door panel.
Loosen jack screw jam nut.
Adjust tip-in with jack screw (clockwise = outward).
Tighten jack screw jam nut.
Lower window.
Tighten window regulator front channel mounting nut.
Raise window, check alignment.
Reinstall access plug & reflector.
If window height is off less than 3mm. (0.12").
Open door and remove both small access plugs (under door).
Loosen regulator jack screw jam nuts (both).
Adjust both jack screws equally.
Close the door and check alignment.
Reinstall access plugs.
Old 17.06.2009, 23:44
myky's Avatar
No onhan tuossa tekstiä ymmärrettävässä muodossa, kun vain tietäis miten ne irroitetaan ettei palaset lentele.. Kuvia onko?
Old 18.06.2009, 13:10
Juhatee's Avatar
Juhatee Juhatee is offline
Aina joku C5 kaupan..
Juhatee on oikealla tiellä
Oma mielipide: kannattaa irrottaa ovipahvi ennen ensimmäistä säätökertaa: Minulla oli hyvät ohjeet alapuolen kumitulppareikien kautta tekemiseen ja silti hommasta ei mainannut tulla mitään kun kaikki piti tehdä "sokkona". Ovipahvin irrotuksen (noin 3 minuutin homma) jälkeen oven sisään näki riittävästi jotta sai selville mikä ruuvi vaikuttaa mihinkin.
Old 18.06.2009, 14:08
myky's Avatar
Kiitos vinkistä! Lähteekä se repimällä varovasti, käsikahvan takaa pari ruuvia pois ja siten lähtee? Peruutuspeiliin ei varmasti tarvitse kajota?
Old 18.06.2009, 14:19
Juhatee's Avatar
Juu, torxit auki kahvan takaa ja nappulapaneeli alareunasta kampeamalla irti. Pahvi irtoaa ensin alareunasta ja sitten sivuilta, lopuksi ylöspäin nostamalla.
Old 22.06.2009, 10:42
myky's Avatar
Ei auttanu säätely, koska se on väljä koko "liukusysteemi" kiskolla. Luulisin että yritin kaikki keinot..
