Old 27.01.2011, 12:52
vette 1968's Avatar
vette 1968 vette 1968 is offline
vette 1968 on oikealla tiellä
M: SBC mekaaninen rullanokka
myyty
cs-304A-R6
SERIAL # UD8092
PART # 12-904-9 CAMSHAFT, CS 304A-R6
CORE C12-9C CAMSHAFT BLANK, CS CHEV 265-400 5160
GRIND # CS 304A-R6
DURATION @ .050 INTAKE 268 ROCKER ARM
RATIO
VALVE ADJ INTAKE .020 DURATION @ .050 EXHAUST 270 INTAKE
.00
VALVE ADJ EXHAUST .022 LOBE LIFT INTAKE .4210 EXHAUST
.00
VALVE LIFT INTAKE .630 LOBE LIFT EXHAUST .4210
VALVE LIFT EXHAUST .630 LOBE SEPARATION 106.0
DURATION .020 INTAKE C/L 106.0
TAPPET LIFT INTAKE 304 CAM ADVANCE 0
TAPPET LIFT EXHAUST 308 HYDRAULIC N
VALVE TIMING .020 OVERHEAD CAM N
VALVE OPEN INTAKE 46 JOURNAL DIAMETER
VALVE OPEN EXHAUST 80 RECOMMEND VALVE SPRINGS 938-16
VALVE CLOSED INTAKE 78 DEPARTMENT P
VALVE CLOSED EXHAUST 48 SPC INSTR FOR CUSTOMER
INTAKE LOBE ID 4024S GRIND INSTR FOR CAM SHOP
EXHAUST LOBE ID 4045S
roller- good for late models with very large engine &long track 4500- 7500 rpm range
nokka on hyvässä kunnossa ja sillä on ajettu noin 2000 km
Hinta olisi nokalla 100 eur /tarj
puh 0400-702858
