pfadt featherlight
onko muilla kokemuksia noista? siis se uusi malli missä BOA nivel ylhäällä.
nyt meinaan vituttaa. 2 viikkoo kerennyt autolla ajaa ja 1mm klappi yhdessä hirvee kolina kokoajan
-65 corvette sting ray coupe -06 corvette Z06 -68 dodge charger -70 plymouth `Cuda -70 plymouth Roadrunner -55 cadillac Fleetwood Limousine -90 chris craft 245Limited 460 king cobra -08 jeep grand cherokee limited www.niklas.galleria.fi |
niin minäkin ekat 1000km
täytyy vissiin laittaa orggisjousi ja iskarit takaisin että päsee powermeetiin ens viikolla. toisessa takacoilowerissa ei ollut mitään klappia eli luultavasti valmistusvirhe. täytyy vielä tsekata etucoilowerit
juu on oikein päin. ei ollut mitään meteliä aikaisemmin mut yhtäkkiä eilen alkoi kolisemaan. saa nähä mitä vastaavat. pistin just viesti pfadtille
Hey Niklas, thanks for the email!
That upper BOA mount uses a teflon raced internal bearing, and it's perfectly normal that after a wear in period that there be a small amount of play between the race and the ball. We've purposely tested the FeatherLights with bearings with large amounts of play in the upper mount and never had it make noise either on our durability tester or on our Test car. Long story short, there will be a small amount of play now that the bearing has been run in a little bit, but there isn't really a situation that would cause it to make noise given our extensive testing on extremely worn bearings. Your noise is likely related to something else in the suspension. First off, identify which corner the noise is coming from now. If you know the noise is coming from the passenger rear corner and you swap the rear coilovers from side to side and the noise doesn't follow your identified trouble shock you can be pretty sure it's not the shock causing your noise. If the exact same noise does follow your identified shock there may be some other issues at play here. To really get to the bottom of this lets try a few things: 1. Disconnect the sway bar endlinks from the car and secure the sway bar away from the control arms. Take the car for a test drive and see if the noise goes away. If it does, you know the noise is sway bar related and not coilover related. 2. Identify which corner is making noise, swap the coilovers side to side and see if the noise follows. If it does let me know and we can go from there. If the noise either goes away or doesn't follow, you've now eliminated the coilover from being the source of the noise. Can you describe the noise it's making, and where it's making it? Do you hear the noise all the time just driving around normal roads? Is it coming in and out of driveways? Is it when you hit a pot hole? Is it a loud bang, or a tick, or a pop? A little more detail would be really helpful here. Lets start by getting a little more information on the car and trying some trouble shooting. Report back to us and we can take it from there! Thanks Niklas! nyt on siirretty oikea taka vasempaan nurkkaan ja nyt kolisee edessä oikealla ja takana vasemmalla. takana hiljeni hetken ku olin siirtänyt sen toiselle puolelle ja samalla käänsin sitä 180 astetta kaikki vaihdettu: puslat,pyöränlaakerit,pallovivelet. kaikki kiristetty 3 kertaan. ei mee mun jakeluun miten ei muka iso välys pidä ääntä ! huomaahan sen heti jos esim koiranluu kulunut powermeetin jälkeen vaihdan orggisjouset takaisin. melko varmasti hiljenee
-65 corvette sting ray coupe -06 corvette Z06 -68 dodge charger -70 plymouth `Cuda -70 plymouth Roadrunner -55 cadillac Fleetwood Limousine -90 chris craft 245Limited 460 king cobra -08 jeep grand cherokee limited www.niklas.galleria.fi Last edited by niklas83 : 04.07.2012 at 00:18. |
Mulla napsahti kummatkin takatolpat poikki yläpäästä siitä kierteen juuresta. Nyt on alla KW inox variant 3.
Tais olla ne vanhemmat musta/hopeat?
toivottavasti saan rahat takas noista. ois vaa pitäny ostaa Lg g2set. niihin voi vaihtaa se laakeri jos hajoaa. noi ei näytä olevan pitkäikäiset huonoilla teillä
noniin selvisi mikä kolisee.
oik etu coiloverin uniball alakiinnityksen akseli oli sen verran löysä että uniball ei ole pyörinyt vaan akseli sen sisällä. selvä välys jo toisessa taka coiloverissa on yläpäässä BOA nivelessä väljää. ja se oli jo heittänyt öljyä pihalle iskarista kalleinta paskaa mitä oon ostanut
Ei kyllä laatu kauhean vakuuttavaa ole
Sano et lähetät noi takasin.
Kuvien kans reklamaatio sisälle + postaus CF:lle aiheesta!
Fix Or Repair Daily |
