Old 01.11.2013, 08:44
YellowRiver's Avatar
YellowRiver YellowRiver is offline
YellowRiver on oikealla tiellä
First supercharged C7 Corvette test
Nyt A&A:lla on ahdin kiinni seiskassa
http://www.youtube.com/watch?v=nZnVh...ature=youtu.be
"A Corvette is a small, maneuverable, lightly armed warship"
- Corvette C5 2002 Convertible
- Corvette Stingray 1972
- Dodge Lil Red Truck 1979
- Plymouth Satellite 1967 2D HT
- Ford Mercury Cougar 1973 XR7 Convertible
- Honda Civic 1977
Old 01.11.2013, 09:25
myky's Avatar
myky myky is offline
myky on oikealla tiellä
Tästä se alkaa...
Old 11.11.2013, 13:13
ruusperi's Avatar
ruusperi ruusperi is offline
ruusperi voi vain toivoa parantuvansa pahoista tavoistaan
Wink
eipä toikaa homma mee iha ku elokuvis,,,viel on pojil matkaa toimivaa vehkeesee.di auto kuitenki vähä erilaine säätää
Old 11.11.2013, 18:50
Onks jossain enemmänkin terinaa ko. projektista?
Old 11.11.2013, 19:07
Tuolla ja loput tuttuun tapaan sisäpiirissä:
"While at the SEMA show, I found out that Comp Cams has cams with 3, 4 and 5 lobes for the fuel pump that can deliver 30%, 45% or 74% more fuel than the stock one. I have a call in to my sales rep at Comp to see how fast I might get one.
I also verified that this is the first supercharged C7 that has actually been driven. Edelbrock just got their car running last Friday and rolled it right onto the trailer. I know the Edelbrock guys and we sort of agreed to help each other with the tuning. If I get it figured out, I'll let them know and vice versa.
Magnusons car may or may not even run. They were kind of sketchy about saying anything. Someone who wasn't supposed to say anything alluded to the fact that it did not run, as far as she knew. LPE has had theirs on the dyno but are using port injectors and a stand alone controller."
http://www.hptuners.com/forum/showth...7-Weird-issues
Old 11.11.2013, 20:19
barum's Avatar
barum barum is offline
barum on oikealla tiellä
Mielenkiintoista nähdä, millainen on LT1:n vääntömomenttipohjainen toteutus.
Saab on käyttänyt tuota Trionic7:ssa vuodesta 1997 lähtien.
Ilmamäärä/palotapahtuma korreloi varsin suoraan saavutettavan vääntömomentin kanssa. Tästä johtuen pyydetään ja säädetään itse asiassa ilmamäärää/palotapahtuma.
Järjestelmässä on sitten erilaisia pyyntöjä (kaasupoljin, vakionopeussäädin, jne.) joista valitaan maksimi ja rajoituksia (luistonesto, vaihdelaatikko, vaihdekohtainen, ahtimen kierrosluku, nakutusäätö, jne.) joista valitaan minimi, joka sitten rajoittaa pyyntöä.
Vaihdekohtaiset vääntömomenttikäyrät ja lämpimän sekä kylmän moottorin maksivääntömomenttikäyrät ilmaistaan kyllä vääntömomenttiarvoina, mutta muutetaan konversiotaulukon avulla ilmamääräksi/palotapahtuma.
Ohjelmointisofta (T7Suite) osaa laskea taulukoiden yhteisvaikutuksen ja näyttää toteutuvan maksimi ilmamäärän/palotapahtuma sekä näyttää sen taulukon/rajoittimen, josta rajoitus lopulta aiheutuu. Ennen kuin ko. ominaisuus saatiin, käytin itse exceliä tämän laskentaan.
Säätöperiaate on varsin erilainen verrattuna perinteiseen kuormitus/nopeus-pohjaiseen säätöön, sillä osien vaihtaminen ei auta, ellei järjestelmälle osaa kertoa, että se kykenee tuottamaan suurempia ilmamääriä/palotapahtuma. Toinen ominaisuus, joka on tuonut joustavuutta on se, että taulukoiden ja vektoreiden x/y-akseleiden skaalaukset ovat myös muutettavissa (eivät siis kovakoodattuja). On joskus tullut sanottua, että T7:sta näkyy insinöörimäinen toteutustapa, ja näin vuosien jälkeenkin on todettava että tekijät ovat olleet joissain osuuksissa vuosia edellä aikaansa.
Lisäksi DI-koneessa ainakin ruiskutusikkunan pituuden, ruiskutuksen ajoituksen ja ilmeisesti polttoaineen paremmasta sumuuntumisesta (atomisaatio) johtuen oikean seossuhteen osalta perinteiset opit pitää päivittää.
Old 11.11.2013, 20:25
Eli ei ihan simppeliä settiä kuitenkaan...
Old 12.11.2013, 02:16
VetteMan's Avatar
VetteMan VetteMan is offline
EX-President
Myös tällainen näkemys ahtamisesta on jo toteutettu C7 malliin.
Old 12.11.2013, 09:12
hateju's Avatar
hateju hateju is offline
Teräsmies
Johan lmr oli kympin vartille rikkonu
Old 12.11.2013, 09:31
ruusperi's Avatar
nii mut ykskään ahdettu ei oo viel kovaa menny,,,siitä tääl puhutaa
kuvat ahtimist pannuhuoneessa ei tarkota valmista systeemii tai nopeet autoo
