Liiketunnistin alkuperäiseen hälyttimeen?
Terve,
Toisinaan tuskaillut että jättääkö autoa ilman kattoa parkkiin jonnekin vai ei ja toisaalta vaikka olisi kattokin päällä niin ei toisinaan olisi haitaksi jos auto varoittaisi "yli-innokkaita" ohikulkijoita että tsootsoo, ei ihan niin lähelle. Elikkä kyseeseen tulisi liiketunnistimen lisääminen alkuperäishälyjärjestelmään. Onko kenelläkään tälläisestä kokemusta tai parempia ideoita ongelman ratkaisemiseksi? Tälläinen http://www.autohalytin.com/product_i...products_id/32 tuli vastaan ja voisi olla melko jees vekotin jos vain osaisi kytkeä originaalihälysysteemiin..
Jotain löytyi:
Upgrade your stock alarm with a shock sensor Introduction. I basically followed this post http://www.c5-corvette.com/c5_alarm.htm The only thing I did different was placing the shock sensor against the drive tunnel - still effective but much easier that way. Materials. You�ll need a shock sensor. I�ve used a CodeAlram IR-S shock sensor, which I got from a local CodeAlarm dealer for $30. The sensor has four wires: Black � ground, Red � 12 V, Brown and Yellow are signal wires. The shock operates by grounding signal wires when vibrations are detected. Yellow wire has about half of the Brown wire threshold and it is intended to be used as a warning signal. Wires. You�ll need a piece of gage 16 or 18 hook-up wire about a feet long. Also you�ll need two wires (of any types) to provide power to the sensor. Methods. Open your BCM compartment in the passenger foot-wall. The BCM module is that shiny box you see on the left (picture 1). Pick it up and rotate the connectors towards you. What you need is a pin N 9 in the top connector. The numbering is from the bottom � so the most inferior pin is N1. Just make it easier � the brown wire seen on figure 2 is connected to pin N6. The green wire is where you�ll need to insert your hookup wire. Once you inserted it � you need to test it. Right above the BCM module you should see three wires wrapped in the black tape: orange, yellow and black (Figure 3). The black wire is the ground. Get it out of the pack. To test your pin 9 connection, stay in the car, close all doors and activate the security with your key fob � the security light should disappear from your dash. Next, connect ground wire with your hookup wire, alarm should sound. If you succeeded this far � you�re 90% there. Next unwrap the orange wire from the tape, it should carry +12V. Test it with your voltmeter. Next, supply power to the sensor from the black and orange wires. Touch it � the sensor should light its LED. Next connect your hookup wire to either of the signal wires and test it by locking the car, etc. If it works you�re 95% done. Positioning the sensor. I decided that the wrapping it around the steering shaft does not justify the pain of disassembling all the panels. Instead � you can just lay it against the carpet and the body of the drive tunnel. Just slide it under the carpet to the left of the passenger foot well. I found that even the lightest tap against the windshield activates the alarm. That might be too sensitive for some of you, but the sensor has a sensitivity dial so it can be adjusted to a setting that suites your needs. Figure 1 Figure 2 [IMG] http://www.seanet.com/~mstanzel/vettepic/securit2.JPG [/IMG] Figure 3 [IMG] http://www.seanet.com/~mstanzel/vettepic/securit3.JPG[/IMG] Lisäksi: http://www.corvetteforum.com/forums/...post1554172170 ja http://www.corvetteforum.com/forums/...post1554172240
Yön yli mietittyä muuten hyvä mutta mitenhän alkup. häly toimii kun se kerran menee päälle? Onkohan niin että ulvoo muutaman minuutin.. Oleellistahan olisi että systeemi varoittaisi pienemmällä äänellä muutaman sekunnin ("chirp") ennen kuin varsinainen häly trikkaa..
On se kätevä. Mulla tunnistaa noin 1m säteeltä liikehtijät. Antaa muistaakseni kaksi varoitusta (joskus enemmänkin) ennen kuin hälyt menee päälle. Laukaisee automaattisesti jos työntää kädet sisälle.
Hälyt ja varoitukset tulee avaimenperään , joten auton tilanteen tietää vaikka ei ole näköyhteyttä. Suurin osa ihmisistä tuntuu perääntyy kun kuulee ensimmäisen varoituksen. Sitten on osa niitä jotka ei välitä paskaakaan. Hipsitään pois kun meteli käy liian kovaksi. Ja sitten on osa joka triggeroi hälyt tahallaan (penikat lähinnä).
Dodge Viper SRT10 Jeep GC SRT8 Crossfire SRT6 --------------------- Ex: Jeep GC SRT8, Viper RT/10, PT Cruiser, Volvo 850 T5R, Caliber SRT4, Corvette 88 |
Mutta sulla taitaa olla Viperin häly? (ei siis automerkin oma vaan tota samaa sarjaa kuin toi 508D purkkikin..)
Tahtoo sanoa siis sitä, että se hälytin itsessään tukee tuota varoitusmoodia. Mutta mun ajatus kun oli että liittäis vain tuon pelkän 508D purkin Corveten orkkishälyyn. Kun liiketunnistinpurkki trikkaa liikkujan ja lähettää pulssin Corveten omalle BCM:lle, niin se tunnistaisi sen kai(?!) niinkuin ovi olisi avattu väkisin tms. Eli sehän jäisi ulvomaan vähintäänkin sen minimi 2min kerralla (manuaalista tarkistin) tai jopa ikuisesti.. Eli ei ihan haluttu toiminnallisuus. Tässä käsityksessä olen tällähaavaa. Ehkä väärässä.
Ilmeisesti Viper tukee ainoastaan sitä lähestymis-Chirp hommaa ----
Mitä jos laittais ihan erillisen järjestelmän tähän sisätutkakuvioon erillisellä sireenillä ja vastaanottimella ? http://www.corvetteforum.com/forums/...ndalism-2.html Tätäkin voisi kokeilla : Just put a label around your vehicle that says "Car will explode if alarm is triggered. Don't believe me? Test your luck ****!" ![]() |
No toistaiseksi en itsekää keksi järkevämpää ratkaisua kuin rinnalle oma systeeminsä. Tosin, probleemahan siinä on se, että se pitäisi saada päälle samaan aikaan kuin auton oma häly. Mieluusti samalla kaukosäätimellä siis. Jos joku tietäisi nouseeko jossain johdossa jännite tai meneekö joku maihin kun originaalihälyn laittaa aktiiviseksi, olisi ongelma jo melkein ratkaistu. Tällä johdollahan nimittäin voisi ohjata tätä rinnalla olevaa liiketunnistinhälyä päälle/pois..
