Old 07.01.2015, 18:39
Patse84's Avatar
Patse84 Patse84 is offline
Patse84 on oikealla tiellä
GM takaisinkutsu C6:siin
#13146: Product Safety - Low-Beam Headlamps Inoperative - (Dec 5, 2014)
Subject:
13146 – Low-Beam Headlamps Inoperative
https://gsi.ext.gm.com/images/999999995.gif
Models:
2005-2007 Chevrolet Corvette
It is a violation of Federal law for a dealer to deliver a new motor vehicle or any new or used item of motor vehicle equipment (including a tire) covered by this notification under a sale or lease until the defect or noncompliance is remedied.
Condition
General Motors has decided that a defect which relates to motor vehicle safety exists in model year 2005-2007 Chevrolet Corvette vehicles. On these vehicles, when the engine is warm, the underhood bussed electrical center (UBEC) housing will expand, causing the headlamp low-beam relay control circuit routed wire to bend slightly. After the wire is repeatedly bent, it can fracture and separate. When this occurs, the low-beam headlamps will not illuminate. As the UBEC housing cools and contracts, the low-beam headlamp function may return. This condition does not affect the high-beam headlamps, marker lamps, turn signals, daytime running lamps or fog lamps. Loss of low beam headlamps when they are required could reduce the driver’s visibility, increasing the risk of a crash.
Correction
Dealers are to install a jumper wire.
Ex: -81 C3. -97 C5. -06 C6
Nyt:
-97 C5. -67 Camaro SS.
Old 07.01.2015, 18:40
Patse84's Avatar
Omassa havaittu valojen vilkkumista tämän takia. helppo homma tehdä itse tuo jumper wire sulake boxiin, sain GM usalta sähköpostilla kuvalliset ohjeet jos eivät suomen gm.llä tee huollossa.
Nyt:
Old 08.01.2015, 00:18
Eikös Länsiautolla ole virallinen GM Finland Oy:n alainen Corvette-huolto. Ainakin ennen on recallit toimineet.
Old 08.01.2015, 01:24
hateju's Avatar
hateju hateju is offline
Teräsmies
Joo ovat noita laittaneen tuossa Bay ja U-J chevroletilla...
ei ollu mitään kutsuja omaan -08 malliin.
Old 16.03.2015, 06:36
Haider05's Avatar
Haider05 Haider05 is offline
Aloittelija
Haider05 on oikealla tiellä
Life begins at 320kmh, the roof on the bottom-????
chessrivals.net
Old 06.05.2015, 19:15
Chevy's Avatar
Chevy Chevy is offline
Löytyi tämmöiset takaisinkutsut,ovatko tuttuja ?
L99.6L80.F body (Zeta)
Old 25.07.2022, 10:18
Silakka's Avatar
Silakka Silakka is offline
Silakka on oikealla tiellä
Moi.
Selvittelin tätä ja laitan tiedoksi teille muillekkin länsiauton kommentit. Suomessa ei ole yhtään tehtaan virallista huoltoa tällä hetkellä eikä länsiauto pääse kirjaamaan tehtyjä huoltoja vin numeron taakse vaikka itse tekisi tai tekisivät. Eivät myöskään saa näistä takaisinkutsuista ohjeita.
Lähin virallinen huolto kuulemma Tallinnassa.
- Mika
Old 25.07.2022, 16:07
Niinpä on näköjään entisessä ja tulevassa neuvostoliitossa tämäkin hoidettu paremmin.
