Old 16.02.2024, 00:23
Maxbrotha's Avatar
Maxbrotha on oikealla tiellä
C6: turvavyon ohitus kitti jos käytössä 4piste vyöt
C6 Corvette Pretentioner Seat Belt Simulator, For Removal of Stock Seat Belts, Each
Eli tällä voit ohittaa kuskin normaali turvavyön jos käytät 4 piste turvavöitä.
When the OEM seat is removed and replaced with aftermarket seats and the OE seat belt is not going to re-installed to the aftermarket seat frame, then our pretentional seat belt simulator must be installed or the SIR Airbag dash warning lamp will illuminate due to the break in the SIR circuitry. Vetteworks has developed the Pretentionor seat belt simulator must installed to eliminate the Airbag warning lamp on C6 Corvettes only.
100¤ sis. postit tai nouto Vantaalta
laine.make@gmail.com
