Pakko mehustaa...
Olen tossa Chris McDonaldin (mcspeed.com) kautta innolla seuraillut erästä Aussi projektia ja nyt kun auto on valmis ja "tullut ulos kaapista" laitan tänne parit kuvat ja tietoa kyseisestä autosta, joka taitaa olla uusi oma suosikki, jos sellaisia nyt enää voi olla kun hienoja autoja tulee aina vaan lisää.
![]() ![]() ![]() ![]() Sitten vähän infoa: 1969 ZL-1 Chevrolet Corvette - Replica RESTORATION / MODIFICATION BY • CLASSIC FABRICATIONS PTY LTD, Fairy Meadow, NSW, Australia ENGINE • 540 CUBIC INCH (8.8 LITRE) DISPLACEMENT - SHAFIROFF ULTRA STREET ENGINE. NEW YORK, USA • Donovan D500 9.8 (shaved 10.2) Aluminum Block • Dart Pro1 325cc Aluminum Heads • Moroso Street/Strip Oil Pan, Oil Pump & Pick Up • HP Harmonic Balancer • Internally Balanced & Professionally Blueprinted • 950cfm BG Mighty Demon Carb • MSD Electronic Ignition. Pro Billet Dist, MSD-6AL ignition control, Blaster SS Coil. • L-88 / ZL-1 intake manifold with Weiand Spacer Plate • Powermaster Hi-Torque Mini Starter Motor • Mahle Custom Coated 10.5-1 Forged Pistons • Comp Cams "StreetRoller" Cam & Kit • Comp Cams 1.7 Pro Magnum Roller Rockers • Crane (HIPPO) Extreme Duty Solid Roller Lifters • Eagle 4340 3D Steel Rods w/L19 Rod Bolts • Callies 4340 Dragonslayer Crank • Billet Specialties Tru-Trak Serpintine system with A/C • Dual Electric Cooling Fans • Flex-a-lite fuel cooler HORSEPOWER • Dynoed @ Factory - 712.5 HP (531KW) @ 6100RPM, 688.9 lbft Torque (934Nm)@ 4600RPM TRANSMISSION • Tremec TKO-600 5–speed Ratios: 2.87, 1.89, 1.28, 1.0, 0.64 • Aluminum Driveshaft • Still to come – Heavy Duty sideshafts DIFF • Still to come 3.73 ratio, at moment standard 308 ratio BRAKES • Standard for now – to be replaced with FRONT 14in Rotor / 6 piston caliper, BACK 13 or 14in. 4 piston. EXHAUST • Hooker Dual SidePipes - 2 1/8 Primaries, 4 inch collector, 4 inch pipes • Car Chemistry muffler inserts • Extra Quieting by GT Motorsport, Kirrawee Australia. WHEELS & TYRES • STREET - INTRO 18 x 10 Pentia, soft lip. 18 x 12 Pentia soft lip. • Michelin 275/35ZR18, 335/30ZR18 Pilot sport • CIRCUIT – Wheels & Tyres (still to come) RADIATOR • Be Cool, USA. Aluminum SUSPENSION • Composite Monospring Front & Back • Sway bars 1 ¼ front ¾ back • Bilstein gas shocks • Polyurethane bushes • Heavy duty Upper / Lower A-Arms • Spreader Bar – links front shocks • Smart Struts & Performance Camber Rod Kit • 6 – Link still to come (waiting for heavy-duty diff before install) STEERING • STEEROIDS Rack & Pinion MISC. • Electrified headlight system by Chris McDonald @... http://www.mcspeed.com/ • Electrified wiper door actuator by Motion Technologies Australia. Also info @ http://www.mcspeed.com/ • Paint by Classic Restorations (Wollongong,Australia) • Engine Metal Fabrication by Classic Restorations • Auto Meter Gauges (behind Radio delete plate) • Heavy Duty Off-set Trailing arms ROLLBAR & CHASSIS STRENTHENING • Classic Fabrications, Chrome moly X piping linking chassis. Chrome moly 4 point Roll Bar Täydet kymmenen pistettä! |
Tämä on niitä autoja jotka saavat sen kuuluisan Corvette kuumeen vaarallisiin lukemiin...
1985 Corvette |
Pari kuvaa vielä:
El Mako, tommosesta puhuin näyttelyssä.
avo C5 ----------------------------------- Ex- 72 avo 350 aut. Ex- 93 avo 350 aut. Ex- 68 coupe 509 & Tremec TKO600 Ex- 92 avo 350 aut. Ex- 68 avo 427 man. Ex- 86 avo 350 aut. Ex- 89 HG 883 Sportster Hugger Ex- 74 Pontiac FB 455 |
Jos vielä saatais video siitä miten nuo mustat jäljet ovat ilmestyneet tuohon asfaltiin..
Niin upea, että melkein ykäsin...
Aika uskomattoman upee ilmestys ja todella tyylikäs toi valkonen väri tuossa perässä sopii hienosti. Nakit on mun makuun myös....tai oikeestaan kuten todettu täyden 10 auto et kauheesti ei tuu muutosehdotuksii
Ei varmaan kovin edullisesti tuohon päästä jos joku muu innostuu unelmaansa juuri tuossa muodossa jahtaamaan
-1990 Bright Red Coupe |
Tosi siisti!! Ei mitään liian överiä
Todella hieno!! Voidaanko sanoa että suomessa digattiin tota tyylia ainakin 6 vuotta sitten? ![]() |
