Old 25.09.2006, 11:09
Harri -76's Avatar
Laiska viimeaikoina
Harri -76 on oikealla tiellä
4-piste suuntaus
mistä löytykään c3:n säätöarvot???
Old 25.09.2006, 11:11
Harri -76's Avatar
Laiska viimeaikoina
... niin ja asialla on kiire.
Old 25.09.2006, 11:13
vaikka tästä
Front 63 - 82 Corvette Daily Driver Advanced Street Autocross Baseline Track Baseline
Toe 1/32" in 0" 3/16 out 0-1/16 out
Camber 0° neg .25° neg 1.5-2° neg 1-2° neg
Caster 2.75° pos 2.75° pos 2.75° pos 2.75° pos
Caster(w offset a-arms) 4.75° pos 4.75° pos 4-4.75° pos 4-4.75° pos
Rear 63 - 82 Corvette Daily Driver Advanced Street Autocross Baseline Track Baseline
Toe 1/8" in 1/8" in 1/8"-1/4" in 1/8"-1/4" in
Camber 0° neg .50° neg .75-1.5° neg .75-1.5° neg
Front 84 - 96 Corvette Daily Driver Advanced Street Autocross Baseline Track Baseline
Toe 1/32" in 0" 3/16" out 0-1/16" out
Camber 0° neg .25° neg 1.5-3° neg 1-3° neg
Caster 5-7° pos 5-7° pos 4-5° pos 4-7° pos
Rear 84 - 96 Corvette Daily Driver Advanced Street Autocross Baseline Track Baseline
Toe 1/8" in 1/8" in 1/16" in 1/8" in
Camber 0° .50° neg .75-2.5° neg .75-2.5° neg
Front 97-02 C-5 Corvette Daily Driver Advanced Street Autocross Baseline Track Baseline
Toe 1/32" in 0" to 1/32" in 1/16" in 1/8"out-1/32" in
Camber 0° 1/4° neg 1/2° neg 1/2° neg
Caster 6-7° pos 6-7° pos 4-6° pos 4-6° pos
Rear 97-02 C-5 Corvette Daily Driver Advanced Street Autocross Baseline Track Baseline
Toe 1/16" in 1/16" in 1/16"-1/4" in 1/8"- 1/4"in
Camber 0° 1/2° neg 1/4 - 2° neg 3/4 - 2° neg
These wheel alignments are not factory standards. These are derived from tests, professional drivers and chassis engineers.You should always consider driver, fuel and cargo weights when your Corvette is aligned. Please note that these specs are symmetrical. For example, when we recommend 1/8" toe in, that indicates 1/16" on each front wheel for a total of 1/8" total toe in. Daily Driver - These specs are designed to minimize tire wear and dynamic forces on front end parts. Driver effort is minimum, the car will steer very "light" and may wander or be "darty" on road with wear ruts. If you are uncomfortable with this feeling, toe the car in up to a maximum of 1/8" total toe in.Advanced Street - These specs are designed to give an even quicker steering response with minimum tire wear. If the car is "darty", toe the car in. By toeing in, you may loose some turn-in qualities gained by the initial specs.Autocross - These specs are a good baseline to start from. The driver must take into consideration that size, compound and condition of the tires. The chassis is affected by the valve package in the shocks, spring rates and sway bars. The Autocross course design and the condition of the surface will also have a bearing. These specs do not work and are not recommended for street use because of adverse tire wear. The car will act "nervous" when ever changing street surface.Track - These specs are by far just a baseline. Those of you who race know alignment specs will change based upon weather, track and unique setup. These specs can also change on each corner of the car and driver to driver.
Old 25.09.2006, 11:18
Harri -76's Avatar
Laiska viimeaikoina
kiitoksia ihan älyttömästi... itse en noita täs kiirees löytänyt... ja takaisin kulmien kimppuun. Niin tietona nyt näin, et katsastuksessa kaikki muu ok, paitsi etuvilkkujen teho, parkkien puuttuminen!
Old 25.09.2006, 11:38
Thumbs up
Eli meni aikas hyvin katsastus
Old 25.09.2006, 11:50
Hienoa! Vielä ehtii ajoille.
Old 25.09.2006, 13:35
ole hjyva vain, vielä siis kerkeät kurvailemaan ennen lumimyrskyjä, vai joko siellä pohjoisessa on pyryttänyt
Old 25.09.2006, 21:29
Harri -76's Avatar
Laiska viimeaikoina
ei ole satanut lunta... mut taas viikko menee turhaan! Ens viikonloppuna laitan viat kuntoon ja ma kilvet kiinni! Eli vielä tekemättä: vilkut ei kelpaa koska valoteho 5w ja ei ole parkkeja!
Old 26.09.2006, 13:33
Helpolla pääsit! Hieno homma! Kertoo vaan, että olet hommat vienyt hienosti loppuun asti. Muista, että se etukilvenpaikka on tallinseinällä...
Old 26.09.2006, 18:42
Tänään justiin kävin kaverin vetten katsastamassa(läpi meni huomautuksitta) ja tuli puhe tuosta etukilven paikasta, nykyisissä määräyksissä sanottiin vain etä autossa on oltava "kaksi kilpeä niille varatussa paikassa"
