Old 08.12.2006, 21:29
C4 X-pertit, onko tietoa?
Tälläisestä autosta:
1994 Lingenfelter Supercharged Corvette – ?POA
This is a true super car. I am the only owner from new. The car has only 18000 miles on the clock – yes this mileage is genuine and guaranteed. The engine was originally upgraded by John Lingenfelter, the engine designer of the Corvette Callaway Sledgehammer, which achieved 254.76 mph. The car was then further upgraded by Geoff Jeal, who installed the Vortec V1 Supercharger, Carrol Water / Alcohol Injection System & Porsche 993 Bi Turbo GT2 Brembo Braking System.
This car has been featured in magazines and has been a numerous times Gold Concourse winner and has had over ?100,000 spent on it.
The current specification of this 1994 Lingenfelter Supercharged Corvette is as follows:
? 750 BHP / 675lb/ft torque & 200++MPH / 0 – 60 MPH 3.5 secs
? Vortec V1 Supercharger running 1 Bar Boost
? Carrol Water / Alcohol Injection System
? LPE Super Ram 58mm Throttle Body
? Competition Cam Hydraulic Roller Camshaft
? Rossler 4 L80E Transmition with 4000 RPM Stall Converter
? Porsche 993 BiTurbo GT2 4Pot Brembo Calipers with 13” Vented Discs
? J&E Forged Aluminium Piston - 9:1 Compression Ratio
? Lunati 5140 Forged Steel Crankshaft - 3.750” Stroke
? Oliver Steel Connecting Rods - 5’850” Length
? Borla 304 Stainless Steel Exhaust System
? CNC Ported Cylinder Heads & Hand Ported Intake Manifold
? Titanium Full Roller Rocker Arms - 1.6:1 Ratio
? Stainless Steel One Piece Valves - 2.00” / 1.56”
? Titanium Valve Spring Retainers - Lighter than Steel
? File Fit Plasma Moly Piston Rings
? Computer Balanced Rotating Assembly
Onko tehty isoja sarjoja? Onko ollut oikein joku LPE paketti, vai onko toi ihan one of? pirre tais jotain mainita, että LPE säilyttää autotiedot tietokannassaan, saiskohan heiltä tosta lisää tietoa? JOs jollain jotain infoa noista vehkeistä lisää, niin laitelkaahan immeessä...
Old 08.12.2006, 21:57
Itsellä ei mitään tietoa moisesta paketista, ikinä en ole kuullutkaan. Ota yhteyttä suoraan LPE:hen ja selitä tilanne, miksi kaivat tietoa jnejne. Siellä on aika asiallinen palvelu ja tuntuvat olevan vastussa tekemisistään. Jos vaikka siellä olisi tuosta jotain tietoa. Pistä Vin samalla mukan jos se on tiedossasi.
Old 08.12.2006, 22:24
Nipa's Avatar
Nipa Nipa is offline
Nipa on oikealla tiellä
Onko vielä Englannissa kaupan tuo? Muistan joskus selanneeni jotain UK:n sivustoa
Old 08.12.2006, 22:25
On joo, lähinnä mietityttää mitä LPE:tä tossa on enää jäljellä...
Old 08.12.2006, 23:00
Mun mielestä Corvette Action Centerissä oli joskus puhetta näistä
Old 08.12.2006, 23:25
heimo huima's Avatar
Mun mielestä toi on one-offi. Omistajalla ei ollu pikkurahan puutetta niin laittoi kaiken uusiksi. Jotain tollaista tuli jubailtua mun kärryn ex omistajan kanssa, kun tunsi ton.
