Old 16.04.2007, 19:07
kokki's Avatar
kokki kokki is offline
Aloittelija
kokki on oikealla tiellä
M: Super Yank 3500 (turbiini) -> 4l60e
Vähän ajettu turbiini, 200e
The Super Yank 3500 is a breakthrough in street/strip converters. By using 21st Century materials and CNC manufacturing, the Super Yank provides a superior launch, without blowing the tires off the line. Our customers typically will pull 60' times on drag radials comparable to their competitor's cars on slicks. Although a SuperYank 3500 can easily roast the tires, you can launch nearly as hard on the street as you could at the strip. The SuperYank 3500 provides great midrange torque. The converter will increase torque out to 4500 rpm on an LS1. This eliminates the flat spots after upshifts and makes second gear a monster even at lower speeds. Because of its lower STR and strong midrange, the SuperYank 3500 teams with 3.73s to form a very hot street set-up. As an additional bonus, the Super Yank is the world leader in efficiency...that means your Super Yank will transform engine torque into rear wheel torque almost as efficiently as a manual transmission! All this in a converter that retains good drivability.
