Old 18.05.2007, 19:31
Z06 Sport Auton "Supertestissä"
Porsche-harrastajien raamattu lienee saksalainen Sport Auto, ja nimenomaan sen "Supertest". Lopulta C6 Z06:kin pääsi näyttämään taitojaan em. testissä.
Tästä testistä mainitsemalla on kiva kiusata hardcore Porsche-kuskeja baaritiskillä..."kannattaisikohan GT3:eenkin kokeilla laittaa niitä run-flat -renkaita jotka Vetessä on, tiedä vaikka Possun aika paranisi...":
"The Corvette Z06 is both, a cruiser and a racer"
"nearly perfect, powerful engine, the chassis and supsension stand the charges of a challenging track like the Nurburgring easily, exact gear shifts and an easy clutch, slight oversteer leads to best lap time"
"even though the clutch feels a bit weak it stands the power of the 8-cylinder engine"
Testikuski Horst Von Saurman lausunto:
HvS' conclusion: "a small (read: unexpected) sensation....in terms of price/performance the European sportscar makers should blush ....the engine is a "hammer" and the suspension is great....for the first time the Vette's build quality comes close to the European standard.....hat off to a car focussing on the crucial factors....the relative low weight shows the serious attempt to do changes where there are most effective."
HvS' editorial's headline: "The pressure on Porsche increases tremendously" (referring to both, Z06 and R8 )
Tekniset tiedot:
7-litres V8 engine
bore x stroke: 104.8 x 101.6 mms
compression: 11.0 : 1
512 PS at 6,300 rpm
72.2 PS/litre
637 NM at 4,800 rpm
0-100 km/h: 4.5 secs.
0-160 km/h: 8.9 secs.
0-200 km/h: 13.6 secs.
Vmax: 320 km/h
kerb weight: 1440 kg
power-to-weight: 355.55 PS/ton
100-0 km/h: 35.1/34.4 m with cold/warm brakes
200-0 km/h: 140.2 m
av. fuel consumption in test: 17.4 l/100 km
18 m slalom: 68.2 km/h
36 m slalom: 134 km/h
110 m evasion test: 142 km/h
wet handling: 1:32.7 mins.
Nurburgring: 7:49 mins.
Hockenheimring: 1:11.7 mins."
http://img205.imageshack.us/my.php?image=ringid9.jpg
http://img209.imageshack.us/my.php?image=ring2rq3.jpg
Old 18.05.2007, 20:33
Jani's Avatar
Jani Jani is offline
Jani on oikealla tiellä
Nopee on peli! Harmi kun ei ole porkea kellään tutulla eikä zetaa itellä..
Old 18.05.2007, 23:10
Talking
Kyllähän tuon arvas.
Old 18.05.2007, 23:48
"close to the european standard" Vissiin standarditason yläpuolella
Old 19.05.2007, 00:53
Ihan samaan ajattelin itekin
Old 19.05.2007, 17:13
LT-1's Avatar
LT-1 LT-1 is offline
LT-1 on oikealla tiellä
Tekniset tiedot:
7-litres V8 engine
512 PS at 6,300 rpm
72.2 PS/litre
637 NM at 4,800 rpm
Vmax: 320 km/h
200-0 km/h: 140.2 m
Eipä ole pojat saanu kulkemaan kunnolla: MOTOR TRENDin testissä kulki 0-100 3,9 s , 0-160 7,8 s , 1/4 mi 11,7 / 201,4 km/h.
Kawasaki Ninja 2000, ZX12R
Old 20.05.2007, 08:31
Toi lehti tuli just käytyä ostamassa jostain Saksalaisesta huoltamosta
Old 20.05.2007, 09:30
Originally Posted by LT-1
Eipä ole pojat saanu kulkemaan kunnolla.
Mikä lie automaattijaakko päässy eka kertaa pakkomaatin kimppuun niin eihän siit mitään tuu
Old 21.05.2007, 08:54
juzzi's Avatar
juzzi juzzi is offline
juzzi on oikealla tiellä
Kannattaa noi ameriikan lehtien drag jockey:n tekemät ajat laittaa aina pieniin heittomerkkeihin...ne kilpailee muutenkin juuri tuolla varttituloksella.
Siis lehdet toisiaan...mikä lehti saa parhaimman tuloksen on "paras" tyyliin.
esim takarenkaita on liottaa jossain "pehmennyslitkussa" yön yli ja kaikki turha paino on autosta poistettu (matot yms pois), etuvakaaja irroitettu yms.
Juza
Old 21.05.2007, 20:05
LT-1's Avatar
Varttimailin loppunopeus ja 0-200 11,7 s kertoo kuitenkin että koneessa on voimaa.
