Old 27.07.2007, 08:22
M: GM High Volume Oil Pump for LS1, LS6, LS2
This pump is the factory GM high volume oil pump that is a direct replacement for the stock oil pump and is recommended in many applications. This pump works with stock timing set and oil pan. Lingenfelter suggests this pump for stock crankshafts and aftermarket crankshafts.
pitte.verre@gmail.com tai YV
Hinta pyyntö 80e + mahdolliset rahdit
Old 01.02.2008, 20:11
Edelleen löytyy pumppu hyllystä,
lisäksi löytyy pari satsia LS koneen laakereita (käsittääkseni käy SBC)
Rod Bearings, Veivien alapään laakerit, kakskymppiä alikoossa
Speed Pro 8-7100ch 20
40e
Main Bearing Set, Kampparin laakerit, stanu koossa
Sealed power 152 M
70e
YV, pitte.verre@gmail.com tai p.040-755 5571
