Old 31.10.2007, 22:39
TJ92's Avatar
TJ92 TJ92 is offline
TJ92 on oikealla tiellä
P1571 ASR Desired Torque
Kertoiskos joku minulle,mikäs vikakoodi tämä on.
Old 31.10.2007, 23:16
Cocco's Avatar
Cocco Cocco is offline
Cocco on oikealla tiellä
Originally Posted by digitalcorvettes.com
10-PCM P1571:
ASR Desired Torque Circuit
PCM supplies 5.0v on Desired Torque Circuit to EBTCM/TCM.
EBTCM toggles 5.0v signal to GND to produce duty cycle signal proportional to ENG output torque reduction requestred by EBTCM (wheel slip detected).
PCM reduces spark advance and can disable fuel injectors.
If PCM does NOT receive the Desired Torque signal the DTC sets.
Conditons for Running DTC
TC has NOT failed
ENG speed > 500rpm for 20 sec.
Conditons for Setting DTC
Desired Torque signal NOT received by PCM for 3 sec.
Action Taken
PCM stores DTC into memory with RUN and FAIL.
MIL will NOT illuminate.
PCM records operating conditions at time of DIA FAIL and stores in Failure Records.
Conditons for Clearing DTC
PCM turns MIL oFF after 3 consecutive RUN trips that do not fail.
A last test fail (current DTC) clears when diagnostic runs and does NOT fail.
History DTC clears after 40 consecutive warm-up cycles, if this or any other emissions diagnostic does NOT fail.
Use a Scan Tool to clear MIL/DTC.
Diagnostics
Remove any debris from PCM\TAC module CON surfaces. Inspect module CON gaskets for correct instllation (prevent water/contaminant intrusion).
Intermittents caused by:
Mis-routed harness
Rubbed through wiring insulation
Broken wire inside insullation
Use a Scan Tool to check values.
This again is a very common intermittent communication failure issue. If this code sets more than 3 times in 1 minute, then the MIL comes on, and you get the dreaded "Reduced Engine Power" message, and your car turns into a slug.
This is a protection mechanism designed to prevent your car from dying in traffic. cycling the ignition after being off for 20 seconds usually restores normal operation.
Most likely you need to clean the contacts between the PCM and the TAC (throttle actuator control module) These contacts are right under the battery, so battery fumes can affect them. Worse case is that your TAC itself is going bad (about $270 bucks).
I would leave it alone for now and just watch it.
Tommosia tuolta äkkiseltään löyty...
Old 31.10.2007, 23:19
http://www.gearchatter.com/viewpost12568.php
Old 01.11.2007, 18:15
TJ92's Avatar
Saiskos vielä selostuksen ihan suomeksi,ei oikeen auennut tämä noista linkeistä.
Old 01.11.2007, 18:30
hakkis's Avatar
hakkis hakkis is offline
Odota vähän.Kyllä kohta joku kielimies sulla homman suomentaa.Pojat vaan halus vähän päteä.
Teiden ritari.
Old 11.05.2021, 11:28
Sami T's Avatar
Sami T Sami T is offline
Aloittelija
Sami T on oikealla tiellä
Täällä odotellaan, koodi kiusaa
Old 13.05.2021, 16:10
Silakka's Avatar
Silakka Silakka is offline
Silakka on oikealla tiellä
Alla tietoa mutta voi olla ettei osu kun et kovin tarkkaan laittanut mitä oireita on ?
Luistelun esto piirivika(väännön rajoitus). Eli pcm pukkaa 5 v jännitteen tuonne ebtcm. Ebtcm vääntää sen kanttiaalloksi joka on verrannollinen luistoneston määrään. Pcm käyttää tätä signaalia sitten tiputellakseen ennakoita jne. vähentääkseen tehoja tarvittaessa. Jos vika tulee päällee, ei pcm saa tota kanttia takaisinkytkennästä.
Stage 1 Tarkista maadoitukset ja putsaa liittimet olis se ensimmäinen toimenpide.
Stage 2 on käydä noi allaolevan linkin juotokset läpi jos ei tokene. Tämä onkin sitten isompi jumppa ja pätee useampaan eri vikakoodiin.
http://c5vette.blogspot.com/2019/03/...-later-c5.html
Näköjään on jenkkilässä tiedossa että vm 97-98 tuo piirin valvonta on ollut liian herkkä ja vikakoodia tullut vaikka autossa ei sinänsä ole vikaa. Tässä tapauksessa sen vikakoodin saa pysyvästi veks hptunersilla tai efilivellä.
